Perform this procedure to enable Energy Efficient Ethernet (EEE) on a port. The default is disabled.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Enable Energy Efficient Ethernet:
    energy-saver eee enable
